NI TestStand
Use Call executable to run bat & ftp
I have a bat file to run some script  and ftp. It work fine when I run it in cmd or window.
But it doesn't work when it deploy it to Teststand.
I wonder any solution for it or where I miss.
(2,248 Views)
Hello Kruchai,
Do you get any error code ? Do you have a small script + sequence example illustrating the issue ? It could be interesting to separate the script and the ftp commands to determine wich part of your script may be problematic.
Note there is build-in FTP steps in TestStand. Perhaps it can adress your needs...
(2,191 Views)
