NI TestStand
Use TestStand API from TestStand IDE.
I have a custom HMI user interface that works very will using the UIEvents to display a live test parameter results. It show the step name, the Limits and the measurement in real-time. Plus a few other things. The question I have is if I lunch the sequence from the teststand IDE, is there a way to to still use the Application Manager in the C# code.  Is there a way for the C# code to once lunched from teststand to subscribe to the UIEvent?
Message 1 of 1
(1,128 Views)
