NI TestStand
User login from code
Hi All,
I have the following question regarding user login. I would like to pass username and login from C# to engine and start it.
I have found some old topics, but links are no longer valid.
axApplicationMgr.Start() displays login dialog, but I would like to avoid and do it in the background.
Mike
(2,020 Views)
The engine calls the LoginLogout sequence of FrontendCallbacks.seq, so looking at the frontend.dll C source code to see how that handles logging in the system user may be helpful to you. I believe as long as you have a valid user in the in the User Manager, you can override this callback, call TS_EngineSetCurrentUser and then bypass the Login dialog in the same manner as how frontend.dll handles the system user.
I know it's not C#, but the method should be equivalent.
I hope this helps.
-Jack
(1,995 Views)
Hi Jack,
Many thanks. Found the source code and will play with it.
I will let you know the result.
Mike
(1,970 Views)
