NI TestStand
Using Extraputty TestStand 2014
Curious if Extraputty is supported by TestStand2014. I've installed putty as well as the teststand steps during installation process. However, while trying to insert a step i don't get an option for extraputty as shown in link below.
http://www.extraputty.com/features/teststand.html
What is necessary inorder to start an SSH connection?
(4,378 Views)
Accepted by topic author JMeye
J Meye,
 This is Ali from National Instrument's applications engineering. Did you have a chance to look at these forum posts below? They are also configuring Extraputty to connect with TestStand 2012. Since there hasn't been too much of a change in either software, did you have any success with following these steps?
ExtraPutty TestStand 2012 Issues:
http://forums.ni.com/t5/NI-TestStand/Starting-TestStand-with-ExtraPuTTY-installed/m-p/2596877#M43310
SSH Communication Review:
http://digital.ni.com/public.nsf/allkb/A254FE727B22258586257B6E002DF401?OpenDocument
Issues with 64 bit:
http://forums.ni.com/t5/NI-TestStand/SSH-and-64-bit-Teststand/m-p/2961873#M46440
Additionally, is this a 32 bit system? There have been issues configuring with 65 bit systems with Extraputty.
Ali S.
Applications Engineering
(4,343 Views)
J Meye,
 This is Ali from National Instrument's applications engineering. Thanks for posting on the  discussion board.
Issues with 64 bit:
Ali S.
(4,343 Views)
Thank you for the response. The first link provided was able to solve most of my issues associated with ExtraPutty. This is a 64 bit system running the 32 bit version of TestStand2014.
(4,260 Views)
JMeye,
 Glad to hear it!
Ali S.
(4,237 Views)
