NI TestStand
Using Rational ClearQuest with Teststand Source Code Control
Has anybody used Rational ClearQuest with Teststand? I would be interested in any views/experiences configuring the source code control from within Teststand.
(3,417 Views)
hello ADL-
It looks as though Rational ClearQuest is an add-on to Rational ClearCase (defect tracking on a source code control package). While I have never worked with Rational ClearQuest before, I have seen integration between ClearCase and TestStand. The primary difficulty I've seen ClearCase users encounter is the actual setup of the software as far as creating new drives and storing all their code on them. Checking-in and checking-out files is fairly straight forward.
My personal experience with ClearCase 3.0 was that it was a little finicky about checking things in for the first time, as well as checking in and out complex sets of files. When problems occurred I was able to launch ClearCase's user interface and got much better behavior.
The KB,
ef="http://digital.ni.com/public.nsf/websearch/E5763AD50D29E44286256CEC0055552F?OpenDocument">TestSt...
, talks about the general nature of SCC connections with TestStand.
Hopefully if there are any users of later versions of ClearCase they can comment on what kinds of behavior they've noted.
--Regards,
Elaine R.
http://www.ni.com/support
(3,417 Views)
