NI TestStand
Using Switch Excequtive with NI TestStand
Hello
I am beginner in NI teststand & NI switch excequtive.
I have NI SCXI-1001 Chassis with NI SCXI-1130 switching slots.
I need a quick help on how to use switching in NI TestStand. What  I am going to do is: generating a signal by a RIGOL Function Generator and switch this signal to excite some piezoelectric sensors and reading the response signals by a Tektronix oscilloscope.
I have read these documents:
NI TestStand 4.0 Quick Start Guide
Getting Started with TestStand
GETTING STARTED GUIDE NI Switch Executive
and so on
But still, I can not switch the signals with my hardware.
Is there any Tutorial to help me in doing my work?
Is there any VI code,  NI TestStand Sequence or Example which can help me?
Please help me asap
Thanks in advance,
Mohammad
(4,504 Views)
Hi Mohammad,
The following are a few documents that outline various ways (including with the Switch Executive) to incorporate switches into your TestStand sequence:
http://zone.ni.com/reference/en-XX/help/370404G-01/nise/teststand/
http://www.ni.com/white-paper/10092/en/
Let us know if those are helpful and keep us updated on your progress!
David R
Systems Engineer
(4,476 Views)
Hi Mohammad,
going even one step back... have you verified that your switches / routes are working properly using NI MAX? Are the IVI sessions set up right?
Using Switch Executive in TestStand is pretty straightforward.
Regards
Oli
(4,448 Views)
