NI TestStand
Using TestStand How I pass an array of data into a DLL (IPC3.dll) for serial communication
I am ussing a DLL created by another party. I have the list of the C declaretions. I have been able to write a seq that can turn the comport ON/OFF or select a different port but I have not been able to send or recieved any data. I have created an array of bytes(unsigned 8-bit integers)to send and recieved data but nothing goes out or in.
(3,463 Views)
Hi Toro,
There is an example in your \Examples\AccessingArrays\PassingArrayParametersToDLL directory that illustrates exactly how to pass TestStand arrays as arguments to dll functions. The source files for the .dll are located in the same directory.
For more information on passing arrays as parameters to modules you should read the "DLL Flexible Prototype Adapter" section of Chatper 13 in the TestStand User Manual, and pay special attention to the subsection entitled "Array Parameters". You can access the User Manual from the TestStand Start Menu group, the TestStand Sequence Editor's Help menu, the \Doc directory, or online at the following link:
http://digital.ni.com/manuals.nsf/websearch/50B69DA356B8D38C86256A0000660E6B?OpenDocumen
t&node=132100_US
Jason F.
www.ni.com/ask
(3,463 Views)
i am using a third party a third party DLL (IOLink.dll) to configure the serial port. but was unable to get the status of the device connected at the other end. can u please debug this. Do i need to add any library files to the VI or do i need any driver files to do that.The configurations i am using are
 OS:Windows XP
Labview Version:8.5
(3,190 Views)
