NI TestStand
Using a batchfile with Teststand
Has anyone used a batch scripts with teststand and or know of any resources on writing batch scripts?
Brian
(2,952 Views)
Hi Brian:
In order to do this in TestStand, you can use the Call Executable step.  If you right click anywhere in a sequence in the TestStand sequence editor, you can find the Call Executable step.  Here you can specify the path to your batch file.
Thank you
Nandini
(2,911 Views)
