NI TestStand
Using a labview variable in teststand
I am using a labview user interface to load a teststand sequence.
I need to use the value of one of the UI VIs terminal in one of the teststand sequence VIs.
How can i do that please ?
(2,450 Views)
Use a thread.PostUIMessage using a UIMsg_UserMessageBase value to request the value from the UI. Set the step to wait for an answer.
In your UI you have a callback to handle UIMessages and return the required value back to the Sequence.
Regards
Ray Farmer
(2,412 Views)
