NI TestStand
Using expression in the Expected String Value field?
I have a sting value test step in TS 3.5. Labview module passes a string to Step.Result.String (Data Source) and I want to compare that string against a string which is in one of my global variables (FileGlobals.string). Can I just put FileGlobals.string in to the Expected String Value field? Or should I do the comparison in the LV? Or...?
BR,
Jick
(3,497 Views)
Hi jick,
Yes you can may enter the Variable into the field
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,491 Views)
OK, thanks!
I was just wondering because there is not a button for launching Expression Browser window in TS 3.5.
BR,
Jick
(3,486 Views)
I think support for expressions in the Expected String Value was added in 4.0
(3,427 Views)
