NI TestStand
Using the Array SetElements function
Hi All,
I'm trying to use the Array SetElements function to set a value to specific indices within an initialized array but I cannot figure out what the syntax is for the optional parameter 2. I've tried a whole bunch that seem to make sense but always get an error. Has anyone used this function before who can let me know what the syntax to use is?
Nick
(4,180 Views)
Nick,
So the syntax for setting all of the elements to a value can simply be written:
SetElements( myArray,valueToSet )
To add in the optional parameter 2 and define a range is something like this:
SetElements( myArray,valueToSet, "[3..6]" )
The .. operator is analagous to a : in Matlab.
Good luck,
Chris
(4,164 Views)
Hi Chris,
Thanks for the reply. I think I tried this format but couldn't get it to work for non ranged elements. What would the syntax be for setting elements 1, 3, 4, 8 etc..?
Nick
(4,154 Views)
Accepted by topic author nickstorton
The SetElements function does not support non-contiguous ranges of elements, so there's not much point in using it if you aren't going to set the whole array or a range of elements. You can just do:
array[1] = 0,
array[3] = 0,
array[4] = 0,
array[8] = 0,
-Doug
(4,149 Views)
Hi Doug,
Thanks for the response, this is the workaround I have been using. It would have been so much neater the other way though. Ah well can't have it all I guess.
Thanks again,
Nick
(4,144 Views)
