NI TestStand
VBAI TestStand steps in TestStand 3.5
The ts_vbai_all.zip available for VBAI 3.x is only compatible with TestStand 4.x.
Could it be possible to get the NIVBAITestStandSteps.ini palette in TestStand 3.5 ?
Jean-Louis Schricke
MESULOG
Jean-Louis SCHRICKE
CTA - Certified TestStand Architect (2008 - 2022)
CTD - Certified TestStand Developer (2004 & 2007)
CLD - Certified LabVIEW Developer (2003 & 2005)
(4,403 Views)
Bonjour,
Veuillez trouver ci dessous la sequence en version 3.5.
Manuel R
AE dans une autre vie
(4,367 Views)
Could you confirm that there is still actually no way, using VBAI TestStand steps, to address two CVS in the same sequence.
Jean-Louis Schricke
Jean-Louis SCHRICKE
(4,272 Views)
You are correct, VBAI can only connect and inspect one target at a time.
(4,221 Views)
Thank you Corbin for your answer.
Is there anything planned at Austin to allow driving more than one CVS with TestStand and VBAI steps?
Jean-Louis SCHRICKE
(4,212 Views)
Hi Jean,
Just to give you another idea you can communicate with more than one by first closing the interface with the other.  In other words you can open communication with CVS#1 and do what you need to do.  Once you are done close this interaction and now you can open communication with CVS#2.  If you need a little help understanding how you might do this I would suggest taking a look at this example.  Custom Vision Builder AI Inspection Interface using LabVIEW and ActiveX   In this example they open communication with VBAI through ActiveX and close it once they are done.  This might help you get started in your application.
Adam H
(4,173 Views)
Adam,
Your solution cannot be used in my project.
There are two CVS driven by VBAI and both CVS are doing inspection in parallel.
On CVS is for functional test and the other one is for packaging test.
As TestStand can handle parallel threads, it should be possible to have two inspection sequences using VBAI steps running in parallel.
Jean-Louis SCHRICKE
(4,169 Views)
