NI TestStand
VI front panel does not pop up in teststand
HI,
I am new to teststand and would like to seek helps on my application.
I have a sequence file consists of several steps. in the SETUP, I have a step to acquire input from the user on which test to run. Having said that, when i run the sequence, i do not see the checkbox test pop up automatically. How do i configure it to pop up the VI automatically.
Also, How do we control the sequence if the user select 3 test cases? using (if) flow control in teststand?
Please advise.
Alfred Tan
(4,820 Views)
Click Step
Module --> Show VI Front Panel When Called (on the right)
PS: next time: upload all you project files in a .zip so that people can run it "out of the box", that helps a lot.
Was this helpful?
(4,815 Views)
About controlling: in your vi: transfer your checkboxes to datatypes that Teststand understands (number,string,etc) and make an indicator of it.
"connect"it as output (front panel icon: show connector) click and click on indicator.
Then it appears (after reload) in teststand
use a if/else or select(switch)/cases
But I think you should start with a Labview tutorial (using subvi's) and reading the teststand manual/tutorial (calling Labview steps)
New programs aren't learnt in a week 😉
(4,811 Views)
Hi HansWi,
Sorry for the late reply.
Thanks for the VI pop up solution. Now the VI can pop up when i call the VI.
I am using "case" in teststand, I still have error message when i run the sequence. Also, The sequece does not follow the checkbox value that checked by the user.
Please advise.
(4,747 Views)
What you need is the Select step then the Case with End then the End for the Select.
ie
Select
 Case
 End
 Case
 End
End
If you drop a Select Step onto an empty sequence you will see the structure you need.
Regards
Ray Farmer
(4,719 Views)
