NI TestStand
VI hangs due to 4 activex components
hi there
This is a VI i set up for viewing 4 video simultaneously and doing other small manipulation.i tried running it but the systtem hangs up and goes to restart mode after playing the videos for sometime.i am just a normal labview user so the code is not optimized at all.Please find a solution for it and give me suggestions to optimise it too..
PS: i have  used a Movie player pro active X component.
 regards
sankar
(3,118 Views)
This doesn't seem like a TestStand related question. You might have a better response if you re-post it to the LabVIEW forum
http://forums.ni.com/ni/board?board.id=170
Regards
Ray Farmer
Message Edited by Ray Farmer on 04-30-2009 06:34 AM
Regards
Ray Farmer
(3,114 Views)
