NI TestStand
VI not found in instr.lib when using Project path
why can teststand not find the VI when i insert the project path to an instrument driver saved in instr.lib?
When i delete the project path then it can be found.
The blinking red error says
"Labview: (Hex 0x7) Datei nicht gefunden. Die Datei befindet sich an einem anderen Speicherort oder wurde gelöscht. Verifizieren Sie in der Befehlszeile oder im Datei-Explorer, dass der Pfad korrekt ist."
Also when i change from adapter=runtime to adapter=development it is working.
Message 1 of 14
(1,944 Views)
Do you have your instr.lib in the TestStand search path list?
Message 2 of 14
(1,915 Views)
Yes, inclusive SubDirs
Message 3 of 14
(1,902 Views)
No Project Path works with RTE
Project Path works with DevSystem
Did I get that right?
Message 4 of 14
(1,882 Views)
Thats correct.
When i change to DevSystem it is working.
Message 5 of 14
(1,879 Views)
I remember having seen this before... yet I don't remember the context
Using Google I found https://forums.ni.com/t5/LabVIEW/LabVIEW-runtime-lvproj-and-Teststand-deployment/td-p/3747113
yet this seems to be deployment related.
What is your motivation for defining the lvproj in the module adapter?
Message 6 of 14
(1,868 Views)
The reason was that teststand is using the correct file.
Currently, after removing the project path, it is finding and using the wrong Initialize.vi.
Message 7 of 14
(1,863 Views)
Valid UseCase!
You've found a strange behaviour there: when trying to reproduce this, I was successful using stuff from instr.lib (independently whether contained in search path or not)
I was not able to reproduce this when using some random code from different directories....
I recommend opening a Service Request at NI 🤔
Message 8 of 14
(1,850 Views)
Could you please share your findings once you have this problem solved?
Message 9 of 14
(1,784 Views)
The workaround is to put the full path in the vi-field.
I dont have a solution 😞
Message 10 of 14
(1,772 Views)
