NI TestStand
VI not same as LavView Run-Time Engine after 2.0 to 3.1 conversion
I get a dialog
Unable to load VI 'Front Pannel Development.vi' with the Run-Time Engine.  It is
possible that the version of the VI or one of its subVIs is not the same as the
LabView Run-Time Engine version.
Note : For optimal execution performance, you should ensure that all your VIs are
compiled to the same version.
Configuring TestStand to use the LabVIEW Development System to run your VIs may fix
this problem.  To change the configuration, go to Configure>>Adapters>>LabVIEW.
Do you want to edit the VI in LabVIEW?
Yes or No.
When leave the Specify Module dialog.  for a step that calls a VI. That VI uses some Labview specific set and get variable sub VIs.  Changing them to TestStand 3.1 equivalent did not get rid of the problem.  I have also tried mass compile on the VI directory.
Any Ideas how to fix this?  I did try the Configuring adapters thingy but that was already right.
(2,925 Views)
Dont forget to mass compile the VI's in the TestStand folder's as well.
Regards
Ray Farmer
Regards
Ray Farmer
(2,913 Views)
