NI TestStand
VI with DLL-call not executable in TestStand when using Runtime-adapter
i am using the latest versions of TestStand and LabVIEW.
In LabVIEW, i created a VI that calls a .NET 4.8 DLL.
Inside this DLL, there's a function that contains a Form which i am displaying using this.ShowDialog.
If I set the TestStand adapter to Development, everything works as expected.
But when I switch the adapter to Runtime, the VI suddenly becomes un-runnable.
If i remove the DLL-call in the VI then the VIs is executable with the Runtime-adaper.
The problem is with the use of the DLL
What can be the problem?
Thanks for help
(411 Views)
Guess the DLL is not in the GAC?
Path resolution is different in RTE compared to the Development Environment
(395 Views)
What is the path of the GAC?
(I tried to copy the DLL into C:\Windows\System32 and C:\Windows\SysWOW64 with no success.)
Why is it a different path? In Labview i selected the position of the DLL with the Browse-button and thought that is hardcoded after this.
(380 Views)
Accepted by topic author OnlyOne
Assemblies have to be installed/ registered in the GAC
https://learn.microsoft.com/de-de/dotnet/framework/app-domains/install-assembly-into-gac
Design decisions 😉
where is the DLL located referring to the VI? Is it within the SearchDirectories?
(368 Views)
The DLL is in the darechpath in TestStand and Labview.
The DLL is in a subdirectory of the VI.
\mystep\myfile.vi
\mystep\support\myfile.dll
Thx for the tip with the GAC. I come back a soon as i test it.
(352 Views)
