NI TestStand
VIs in LLBs - Workspace Pane and Workspace Documentation Issues
I've started experimenting with Workspaces and Projects under TestStand 4.1.
I created a workspace and project, then added a sequence that contains calls to VIs stored in an LLB.
If I perform 'Insert Code Modules' for the sequence from the Workspace pane, the VIs are added to the logical 'CodeModules' subfolder. VIs located in an LLB can't be double-clicked to open them. VIs NOT in an LLB can be double-clicked and opened via the Workspace pane.
Also, when I use the Workspace Documentation tool, VIs located in LLBs are included in the documentation, but the date/time stamps for these VIs all show 12/30/1600 7:00 PM.
(3,028 Views)
Hello Phillip,
Thank you for posting on the NI Discussion Forums.  If you wish to see this feature changed in future versions of the TestStand Sequence Editor, feel free to make a product suggestion.  We take a serious look at these before making decisions on what features will be added.
Chris_G
Sr Test Engineer
Medtronic, Inc.
(3,010 Views)
Phillip,
This was reported to R&D (#128016 and #128019) for further investigation.  Thanks for the feedback!
Chris_G
Sr Test Engineer
Medtronic, Inc.
(2,996 Views)
