NI TestStand
Verify data captured by USRP B200
Hello everyone,
I am using USRP B200 to capture data at a particular bandwidth. I wanted to know if I can verify whether the capture has been done properly. Is there any tool to do that ?
Arohan
(2,155 Views)
This forum is for NI TestStand.  Are you using TestStand to call the B200?  If so how are you calling it?  What data are you returning that you want to analyze?
Here's more info on what NI TestStand is: http://www.ni.com/en-us/shop/electronic-test-instrumentation/application-software-for-electronic-tes...
You can definitly use it to analyze data and determine if the data is good or bad.  What do you want to do with the data?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,129 Views)
