NI TestStand
Veristand unable to connect to PXIe-8840 Linux RT target
When using Veristand 2024 to connect or deploy to target we get error 63.
We removed Veristand engine and replaced it but error 63 still present.
Both target and host running 2024 Q3 Veristand version.
Am able to successfully ping target from host PC.
Ni MAX shows the PXIe-8840 is connected and running.
No password has been set on target.
Are we missing something?  We've run out of things to try - any ideas out there?
(461 Views)
Try Access Console and VeriStand Logs for NI-Linux Real-Time Targets
You should be able to see VeriStand Engine idle. Awaiting command...  if the VeriStand engine is installed properly on that target.
https://tmesystems.net/
(435 Views)
