NI TestStand
Versions of TestStand
I am trying to help a new customer remotely, before I travel the several hours to their site, straighten out some questions with their test system. They think they have TestStand 4.2 and 4.5 installed, don't know what version LabVIEW was used to create their test VIs. Looking at the compatibility chart on the NI site shows TS versions to 4.2.1 and then they switched to the year versioning like LabVIEW, with TS2010. They are pretty unfamiliar with NI "stuff", and I am trying to think of the right questions, did tell them to launch MAX, which if it is on there will resolve the what is installed questions.
So, what versions were there? Was there a 4.5 (4.3, 4.4?)
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,664 Views)
4.5 is TestStand 2010. There wasn't a 4.3 or 4.4.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,633 Views)
Thanks, I suspected something like this, sort of like when MicroSoft started using years for the version, it still was WindowsNT 5.x or whatever.
Putnam
LabVIEW Champion
(2,596 Views)
