NI TestStand
Vi doesn't see another updated vi
Vi1 has been updated to add a new control terminal, the connector pane has been updated, and the file has been saved. Vi2 calls Vi1 but the new connector prototype does not show up. Perhaps it is because Vi1 is a class member? It is closed and if I re-open it the new connector is there. I even shut down LabVIEW completely to no avail.
jvh
(3,263 Views)
jvh,
Is this used with TestStand?
Regards
Ray Farmer
(3,242 Views)
Yes, it is used with TestStand.
(3,237 Views)
Seems the problem has cleared. Edited the file from .lvprog and rebooted.
jvh
(3,232 Views)
