NI TestStand
Viewing a specific sequence execution belonging to a TestStand Workspace in LabVIEW Simple UI
I have a TestStand Workspace which contains 3 sequence files : one master sequence which contains PreUUt, PostUUT..And two other slave sequences that are called from the main sequence depending of a given parameter (It means that during a whole execution only one slave sequence will be called).
Using the TestStand Simple User Interface in LabVIEW, I want to show the completed execution screen of the slave sequence file called.
The problem that LabVIEW shows the master sequence at the end of executions which didn't give details about the slave sequence steps' status.
(3,494 Views)
The step that calls the slave sequences needs to have reporting turned on, as do the steps inside of the slave sequence.
Step Properties >> Record Result
CTA, CLA, MTFBWY
(3,484 Views)
Thanks for the reply,
I found that the record result is already activated as mentionned.
To make it simpler, supposing that we have a sequence file which contains many sequence call modules, like the example in the attachement.
At the end of the execution, I want to be able to view the status of all steps of "Sequence_2" for example.
(3,481 Views)
do you mean in the Report window or the Execution window?
Regards
Ray Farmer
(3,476 Views)
Execution window
(3,470 Views)
