NI TestStand
Virtual keyboard
How do I enter the serial number in Test stand (Ver3.0) using virtual keyboard (created in Lab View).
(3,306 Views)
You could use the "Teststand-set property" function in you virtual keyboard VI, to set the Teststand UUT serial number property.
The path to the serial number property is:
RunState.Root.Locals.UUT.SerialNumber
This KB contains details on this:
http://digital.ni.com/public.nsf/websearch/616AB6FEA929F42286256ABF0072ABF0?OpenDocument
(3,306 Views)
Hi Mr SSL,
As you are using TestStand 3.0.
Make sure your output string from virtual keyboard VI is connected to the VI's connector pane.
When you specify your module in your teststand step you will see the output of your VI made available to allow you to specify a TestStand property. If you have placed this VI in the PreUUT sequence, then set the output string to pass the value to Locals.SerialNumber.
I have attached an example.
Regards
Ray Farmer
Regards
Ray Farmer
(3,306 Views)
