NI TestStand
Wait for Step Labview Code Module running as Parallel thread
Hi
I have configured a step( a labview code module)
to run as parallel thread  (Synchronization - batch Synch- parallel)
I want to wait for this  step to complete. Its not a seq call . how to get the Object reference for this execution
(4,747 Views)
yes its a tricky question
(4,735 Views)
It's possible to make the settings for the parallel thread in the sequence call options.
There is a good example : Testing UUTs in Parallel - Batch Model.
Maybe you can post your sequence?
Kind regards,
Dennis
(4,677 Views)
thanks Dennis
I will try that.
(4,671 Views)
