NI TestStand
Wait for a key-input
Hi!
Is there any expression that can check if the Left_mouse_button is clicked?
Or maybe, make a loop where it waits for the left mouse button to be clicked.
It doesn't have to be a mouse click, a keyboard input is also helpful.
Is this possible?
Thanx
Best regards
Selvakumar C
(3,415 Views)
That applies to the Expression Control and intended in the OI.
Basically you would have to jump of TestStand into some code mudule and monitor your key press.
Regards
Ray Farmer
Regards
Ray Farmer
(3,402 Views)
Hi Selvakumar,
Ray is correct.  Without a Operator Interface or a code module, you would not be able to use the KeyPress Event.
If you goal is to have your sequence pause until the user presses a button to continue, placing a message pop-up step in your sequence would accomplish this.
Jessica
Product Support Engineer
(3,313 Views)
