NI TestStand
Want to confirm that .NET handles the release of TestStand resources for me - unlike LabWindows\CVI
In my LabWindows/CVI UI I know I have to be diligent with releasing references and freeing memory when using various TestStand methods, or getting the handle from a property. Specifically using CA_DiscardObjHandle and CA_FreeMemory. If I miss something the dev. environment tells me of a memory leak at the end.
In a .NET module though, am I right in thinking that all the memory issues are taken care of and I don't have to concern myself with releasing resources?
Thanks!
Ronnie
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
(3,506 Views)
Accepted by topic author Believer
You are correct. However, in the rare instances where you have to call a TestStand method in addition to releasing a reference, you still need to call the method. In particular, I'm thinking about Engine.GetSequenceFileEx and Engine.ReleaseSequenceFileEx. I can't remember if there is another case like that one.
(3,505 Views)
That's good news. For the rare circumstances you mention, do you know if the Visual Studio environment will inform of any memory leaks like the CVI one does?
(3,502 Views)
Any leaks should be displayed on exit if Configure>>Station Options>>Preferences>>Debug Options>>Report Object Leaks is enabled.
(3,500 Views)
