NI TestStand
Warning about skchui.dll
One thing you might try is making sure your path to the cfg files in the Station Options is correct.
One thing I have noticed is that teststand reads the data from the cfg folder but if this is not explicitly defined in the Station Options ie just pointing to the \teststand x.x folder rather than \teststand x.x\cfg then a set of ini files are created in the \teststand x.x folder rather than updating the correct set.
Delete any rouge ini files, once you have done this you might find your warning message stops.
regards
ray farmer
Regards
Ray Farmer
Message 21 of 22
(1,465 Views)
I had a similar problem with removing that problem from my workstation and it wasn't fixed untill I disabled all user input options under every installed Microsoft program. Once I went through and disabled it under all "Currently installed programs" it went away. I think mine didn't go away untill I disabled the handwriting component.
Why do geeks think Halloween and Christmas occur on the same day?
Because 31oct = 25dec!
Message 22 of 22
(1,421 Views)
