NI TestStand
Warning message after teststand user interface exit
I have customized the Teststand simple user interface , after i run the userinterface and after exit, i am getting warning message popup . PFA attached snapshot. Any idea on this . The number of reference in popup varies each time.
Anand
(2,634 Views)
Hi Anand
Looks to me as if you are opening references to TestStand objects (probably in the bit of the UI you have customised) and not closing them after you are done with them.  Check out Close Reference and where and how to use it.
Steve
(2,615 Views)
Hi Steve,
Thanks, I will check that .
Recently i have posted a question on sending .Net object reference from  teststand UI to teststand.
https://forums.ni.com/t5/NI-TestStand/set-object-reference-of-teststand-variable-from-teststand-user...
Above is the link, Can you please check this. I was using GetValDispatch and setValueDispatch property object method  but it is not working.  I am stuck in that. Please check once.
Anand
(2,612 Views)
