NI TestStand
Way To Add Username Field To Login box?
Hi everyone, is there a way to add a username field to the login box when TestStand opens up?  I want to know that the user is an operator but also I would like to know the operator's name for report logging.
Thanks!
(4,781 Views)
That dialog comes from the FrontEndCallback.seq.  You can edit this and add your own dialog.  The source code is also available for that dialog.
https://forums.ni.com/t5/Example-Code/Customizing-the-TestStand-Login-amp-Logout-Procedure/ta-p/3619...
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,768 Views)
You also have the option to add operator names to the list of logins.
(4,762 Views)
