NI TestStand
What does a Setup / Initializing VI look like
I am brand new to TestStand and have no experience so far (apart from the first training course in TestStand). I am also the first in our company and therefore unfortunately have no direct contact person.
I would therefore like to ask what exactly a VI for initializing an instrument looks like. More precisely, I would like to initialize an analog input (PXI-4304) and then read it out in the Main and make a decision. Finally, it should be closed again in Clear Up.
I am very grateful for any help. Thank you very much.
Greetings Lucas
(605 Views)
Similar to the course.....
You initialize the driver session along with some general instrument settings (Setup)
before you do the actual measruement (Main)
and better not forget to de-initialize after yo are done (Cleanup)
(576 Views)
Thank you very much!
I think, I first have to learn how exacly the DAQmx VI is working 😄
Just another Question, why am I passing "DMM" in the Actions around?
For example, in the setup there is a Parameter "DMM in" which hat the Value "DMM"? Whats the sense behind that?
(571 Views)
This is just a placeholder to show the usage of variables to pass around references/ sessions.
With DAQmx you'd have a variable type LabVIEWIOControl which holds the session used by the DAQmx driver.
(564 Views)
When I Create a DAQmx Chanel in the setup, i have to pick a physical channel, but how can i just setup the analog input and pick a channel in the main sequence?
For example if I want to read multiple channel inputs one after another.
Or do I have to Inizialize every Channel for its own?
(548 Views)
Accepted by topic author LucasHapple
You can use differnt options with DAQmx. Yet this is rather a general DAQmx question than a TestSTand question.
I recommend working through the examples and tuorials for DAQmx.
(535 Views)
