Hello Capt. Jack,
The files that are installed with the TestStand Engine are located in the \Setup\Engine directory. These include the CVI Run-Time Engine, LV Run-Time Engine and various others.
The default files that are installed are everything in your \User\Components directory as well as \Cfg\ToolMenu.ini. If you wish to have other files installed, such as the StationGlobals.ini file, please follow the instructions outline in Chapter 17 of the TestStand 2.0 User Manual titled "Ditributing TestStand".
