NI TestStand
What happened to knowledge base?
Was searching for property loader string array examples in developer zone, link was broken. Then tried to goto knowledge base and that link was broken too.
jvh
(3,782 Views)
jvh,
Is this the article you were looking for (or would it suffice as the example you need)?
John B.
(3,750 Views)
It's a partial solution. Would be nice if the article mentioned that the best way to import an array is to first export a prototype using Tools > Import/Export. It says almost nothing about importing.
Still wondering about the whereabouts of Knowledge Base.
thanx for posting.
jvh
(3,738 Views)
If you are going to complain about broken links, you need to provide the link that is broken.
I have no problem going to the Knowledge Base.
(3,715 Views)
