NI TestStand
What is the best way to Query for a PXI Chassis in TestStand
Hi All,
I have some benches that have a PXI Chassis and others without.
I would like to Query for the Chassis and if it isn't there I will use another method of testing.
Is there a way to query for the chassis and if there is how?
Message Edited by glennjammin on 10-09-2009 09:23 AM
Glenn Ellis
(3,518 Views)
Accepted by topic author glennjammin
You could use the VISA Find Resource function. If you get back PXI[bus]::device[::function][::INSTR] or PXI[interface]::[bus-]device[.function][::INSTR] then you have a PXI chassis
regards
Ray Farmer
Regards
Ray Farmer
(3,506 Views)
Thanks Ray for your response.  I tried something similar (_iviswtch.llb\IviSwtch Initialize.vi) and it worked but I have to close the session right after for the switching to work correctly.  I will try the way you suggested and see if it is a better way to go.
Glenn Ellis
(3,482 Views)
