NI TestStand
What is the best way to iterate through all steps of a sequence and sub sequences in edit time via the API. (C#)
I am trying to figure out how to iterate through all steps of sequence, sub sequences included in a code module with C#.
I am using a custom editor and have added a sequence call back method in the Configure menu. When this method is called, the code module is called with as argument the RunState.ThisContext
With following code, it is possible to iterate through the sequence at run time but not at edit time.
Is there another way to get the sequence file at edit time?
How to get the sub sequence files at edit time?
sequenceFile = TestStand.SequenceContext.ProcessModelClient;
if (sequenceFile != null)
    int intNumberOfSequences = sequenceFile.NumSequences;
    for (int intSequenceCounter = 0; intSequenceCounter < intNumberOfSequences; intSequenceCounter++)
        sequence = sequenceFile.GetSequence(intSequenceCounter);
        // Iterate through all step groups
        IterateSequence(sequenceFile, sequence, StepGroups.StepGroup_Setup);
        IterateSequence(sequenceFile, sequence, StepGroups.StepGroup_Main);
        IterateSequence(sequenceFile, sequence, StepGroups.StepGroup_Cleanup);
Best regards
Patrick
Message 1 of 1
(3,842 Views)
