NI TestStand
When I copy a TestStand project to a different computer, why would all the paths/links break?
Two duplicate (copied) TestStand sequences have the same absolute path on two computers, but the sequence on one computer cannot see any of the LabVIEW VIs nor sub-sequences.
What might cause this?
(3,117 Views)
Do they have the same Search Directories?  Go to Configure>>Search Directories and make sure they match. Also the VIs/dependancies have to reside on that PC in the same spots as well.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,111 Views)
