NI TestStand
When I hit "create vi" button in a labivew action step I'm prompted for path, new vi doesn't pop up.
I have always used TS 3.1 and Labview 7.1.  When I hit the create vi button in an action step, a new vi always popped up in 7.1  Now I have installed TS3.5 and LV8.2 and now I'm just prompted for a path.  A new vi does not pop up.  When I go to configure adapter and select Labview, the correct version of Labview is shown (8.2) if I use 3.5 (and 7.1 if I switch and use 7.1).  Now also when I go back to 3.1 and 7.1 the button no longer works either.
(3,075 Views)
If you enter your VI name in the Path and Execution then press Create VI.. It will create the VI in the location of the SequenceFile. See Attached JPG
If you leave the Path and Execution empty when you press Create VI, you will be prompted for a path and filename for the VI.
Hope this helps
Regards
Ray Farmer
Message Edited by Ray Farmer on 01-12-2007 09:48 PM
Regards
Ray Farmer
(3,073 Views)
