NI TestStand
Where and how the Result data type is defined?
I was trying to find where and how the data type Result which an array of them appears in Locals as soon as we insert a step and I couldn't find it in the Types tab.
Thanks.
(2,631 Views)
If you mean the ResultList array, it is automatically created by TestStand in a new sequence.
You can read a more about it in chapter "Result Collection" here:
https://www.ni.com/en/support/documentation/supplemental/08/teststand-report-generation-and-customiz...
The Result data type for default steps is defined in NI_Types.ini, the document mentioned above also explains how the results are copied from the Result data type of a step to the ResultList array.
I hope that this information helps you.
Mathijs
(2,563 Views)
