NI TestStand
Where is executable?
Upgraded TS from 4.2 to 4.2.1 and built a deployment and placed it on the target machine. Where is the 4.2.1 executable located (hiddden)?
thanks,
jvh
(3,664 Views)
Hi jvh75021,
When you are looking for the executable do you mean the sequence editor?  It is typically found in the bin file in the directory you specify in the deployment utility. Have you checked to make sure that you are including this in the utility as well?
Ryan T
(3,631 Views)
And place a shortcut like this
(3,617 Views)
I am looking for TestExec.exe for 4.2.1. to replace 4.2.
(3,608 Views)
it should be in the same location, assuming TestExec.exe was rebuilt for 4.2.1
Regards
RayF
Regards
Ray Farmer
(3,603 Views)
