NI TestStand
Where is the station options configuration stored
Where is the station options configuration gets stored in TestStand 4.2.1?
(5,452 Views)
The StationGlobals.ini file is in your TestStand Config directory, which is found at <TestStand Application Data>\Cfg.
On Windows 7, this is C:\ProgramData\National Instruments\TestStand 4.2\Cfg. I don't remember off-hand what the exact path is on versions of Windows earlier than Vista... Somewhere under C:\Documents and Settings\<Username>\. You can just search for StationGlobals.ini if you need to.
(5,447 Views)
Hi Asbo.
Thanks for the response.
When I open and see the stationglobals.ini I could see the station global variables what I defined in my setup. But I couldn't see any information regarding the station model to be used. Where is this option gets stored?
Ramjee V
(5,442 Views)
Accepted by topic author ramjeev
cfg/TestExec.ini
(5,425 Views)
