NI TestStand
Which "Output Name" in ReportOptions.Directory target in ReportOptions callback
In "Result Processing", I have two "Generate Report" steps. These two steps save the report in two different locations. I want to change the directory dynamically in the TestStand sequence using Report Options callback for the one step and leave the directory path for the other step unchanged.
Is this possible in ReportOptions callback?
Does ReportOptions callback directory parameter target only the directory for the first "Generate Report" step?
Message 1 of 8
(3,167 Views)
Accepted by topic author SumitN
I assume you mean you have two report processing configurations in the Result Processing dialog box.
Your ReportOptions callback is called separately for each configuration. In the callback, the configured settings are passed in the ModelPlugin parameter. The report specific settings are under Parameters.ModelPlugin.PluginSpecific.Options.
Message 2 of 8
(3,147 Views)
Thanks James,
I can use Parameters.ModelPlugin.PluginSpecific.Options.BaseName to point to the result processing configuration I would like to target to change the directory path.
Message 3 of 8
(3,134 Views)
Also, cant I use Parameters.ReportOptions.BaseName in place of Parameters.ModelPlugin.PluginSpecific.Options.BaseName
Message 4 of 8
(3,126 Views)
Yes, Parameters.ReportOptions is just a shortcut to Parameters.ModelPlugin.PluginSpecific.Options.
Message 5 of 8
(3,124 Views)
So I assumed BaseName points to the name of the configuration. Is BaseName the "Output Name" that is shown in the "Result Processing" dialog? If not, I am not sure which variable to check for the "Output Name".
Message 6 of 8
(3,122 Views)
BaseName is the text entered in the Report Options [dialog] >> Report File Pathname [tab] >> Generate Report Path [group box] >> Base Name [edit control].
You can edit the options, breakpoint in the ReportOption callback, and then explore the contents of the parameters in the variables view to quickly see what values are in what places.
Message 7 of 8
(3,118 Views)
Found the variable that has the "Output Name":
Parameters.ModelPlugin.Base.DisplayNameExpression
Message 8 of 8
(3,108 Views)
