NI TestStand
Why Teststand is printing new line as \r in Test Report
i have a string variable created in teststand and i have assigned the below string to this variable..
"Data Value PASS
The Test data Passed"
When i am trying to print this string variable i am seeing something like below printed in the test report. it is adding \r at the end of the current line.
"Data Value PASS \r
Any idea how to fix this?
(3,404 Views)
Hey Diana,
Can you post your steps to recreate this?
(3,378 Views)
Attached my Sequence
(3,366 Views)
Hey Diana,
Thank you for the sequence. This is a known issue with TestStand currently being tracked with ID of 141627.
The current workaround depends on the report format. It is listed on that document. Please let me know if it does not work for you.
Thanks!
Roxy
(3,350 Views)
