04-19-2010 09:30 PM
I have a custom step type which uses a custom data type. When i open the sequence, Teststand immediately modifies the step type and says (modified) next to the version in the types view. Also it puts a star mark next to my sequence file name. Now i save my file and close it. When i open the file again, Teststand modifies the step type again and puts a star mark mext to my sequence file name. From other posts, i have found that it has something to do with my custom data type version.
Any more light on this issue would be much appreciated.
04-20-2010 01:02 AM
Hi Sarasvisu
It seems you have a type confict.
You could use SequenceFileDiffer.exe to solve it.
or maybe you could slove it with TS editor itself
just goto
1.) Configure->StationOptions->Preferences->"Before Saving Modified Types:" Set to "Prompt to Increment Types"
2.) If using TS4.2 Configure->StationOptions->File->"Allow Automatic..." Set to "Never"
Hope this helps
Juergen
04-20-2010 01:24 AM
Hi Juergen,
Thanks for your reply. I just found out one of my step variables property was set to SHARED. I don't remember why i set this to SHARED. But definitely this is causing the issue. When i reset the flags, now Teststand does not update the types folder. Everything is sweet now. Also Teststand used to take lot of time for processing, so when i click any of my step type, i used to get the hourglass for few seconds. Now it doesn't happen anymore. Never play with SHARED property anymore.
