09-15-2006 03:39 PM
09-18-2006 12:48 PM
09-18-2006 03:33 PM
10-26-2011 02:36 AM
Is there any new solution to this? I have same problem and don't want to reinstall all the NI software because I can lose all the components and cofiguration.
Thanks in advance
10-26-2011 02:52 AM
You could try deleting the Users.ini file in CFG folder then launch the TestStand SeqEditor. The file should be rebuilt with the default users and priviledges.
10-26-2011 03:48 AM
Hi Ray,
Thank you for the prompt answer. It did not help either but maybe it depends on I'm using TestStand 3.5. Anyway I will try to describe what happened.
I checked the box "Check User Privileges" under Station Options->User Manager and after that when I open Teststand Sequence editor it opens but all functionalities are grayed out. If I open some sequence it shows error code "-18360. User does not have required privilege".
I have TestStand installed on other computer and there I can check and uncheck "Check User Privileges " without any problems. The difference is when I start TestStand on the other computer TestStand shows up a login dialog and the first one does not.
Since I have done this on the other computer without problems I thought this will not be a problem either but now it cause me problem out of proportion.
Hope you or anyone can help me.
Thanks in advance
Giang
10-26-2011 05:13 AM
you might want to check the other cfg files in the cfg folder and make sure they are not empty (ie 0 in size). If they are delete them and then launch TestStand SeqEditor.
10-26-2011 05:57 AM
Is your Users.ini file located in the default location or are you setup to look in a different folder, because this looks like either your teststand administrator settings have changed or you haven't got an administrator type user defined.
10-26-2011 06:53 AM
Hi Ray,
Yes the users.ini file was in default location, it seems that not only the users.ini is the issue here. Anyway I have replaced "Component" catalog from the other computer and and it works, of course some files from this catalog will be missing but I just need to copy from the old "Componet" catalog.
Thank you for helping me.
Best Regards,
Giang
10-26-2011 12:29 PM
You might have overridden the loginlogout callback in your frontendcallbacks.seq file in the TestStand Components\User\Callbacks\FrontEnd directory. If you overroad the callback you will not get the login dialog and thus will not be able to authenticate as one of the users.
Hope this helps explain what you are seeing.
-Doug
