NI TestStand
Why do I get Operation Failed. [Error Code: -17500]?
After test Stand has finished a test run and has generated a HTML file. I get the following Error Operation Failed [Error Code -17500]. The report is generated but not displayed in TestStand.
(4,552 Views)
What version of IE have you got installed?
Regards
Ray Farmer
Regards
Ray Farmer
(4,550 Views)
IE 7 is installed.
(4,547 Views)
Is this in the Operator Interface or the Sequence Editor,  and what version of TestStand are you using.
Regards
Ray Farmer
Regards
Ray Farmer
(4,544 Views)
Hi Ray,
It happens with CVI Operator interace I am using TestStand v3.5.
It does not happen every time a unit runs.
When it happens it will continue to occur until the Operator either selects stop at the UUT Information prompt and then restarts or shuts down TestStand.
Pat
(4,542 Views)
Hi patoh,
Can you open the report in just and external instance of IE7? Have you made any modifications to the CVI operator interface?
Does this also occur in the development environment (or any other OI?).
Does the report contain anything like graphs or images?
Does this problem occur with every sequence you run (have you tried any of the examples)?
Have you tried lowering the security settings in IE7?
Regards
Jon B
NI UK & Ireland
(4,503 Views)
