NI TestStand
Why do I get error -17313 in my TestStand sequence?
Type of argument expression 'Parameters.Module' is incompatible with parameter 'Module'. Expected Container, Instance of Type 'TempController_Limit', found Container, Instance of Type 'Heater_Location'
-17313; Could not accept the parameter passed in.
Why do I get this error? I am 99% confident that I have specified module and parameters properly? If I disable Type Checking on these parameters I get no other error. How is this error introduced?
The only other clue is that my sequence is running two threads? All parameters passed by reference.
(4,199 Views)
The TS Reference Manual 12-2, for passing a container as a parameter you do have to switch off type checking for that parameter.
Regards
Ray Farmer
Regards
Ray Farmer
(4,198 Views)
Thanks for the answer. My problem was that I had not specified parameters properly through the sequence. So I think the stack was probably getting corrupted etc..
(4,189 Views)
Francey -
As a side note, internally TestStand does not use the stack to pass data between sequences, so your data integrity was probably ok, it appears to be just a type mismatch that we caught.
Scott Richardson
https://testeract.com
(4,177 Views)
