NI TestStand
Why does TestStand use both comma and period for decimal point separation?
TestStand stores our test data to a SQL server using SQL Server Stored Proc, but for some reason a comma is used for separation (double values) for "PROP_NUMERICLIMIT.HighLimit" and "PROP_NUMERICLIMIT.LowLimt", but not for "PROP_RESULT.Data" (or any other numeric value field). Why is that? I haven't been able to figure out if it is a bug or if I have missed some step in the configuration.
(4,385 Views)
I ran across this in the TestStand Help. You might want to try the change in the ODBC Administrator.
When you use the MySQL ODBC driver and the operating computer specifies a comma character as the decimal symbol character, the ODBC driver might return an error because the ODBC driver internally converts a floating-point value to a string value. The computer locale causes MySQL to interpret the comma decimal symbol character in the SQL syntax as a multi-value list character separator. Configure the MySQL data source in the ODBC Administrator and enable the Don't Use Set Locale option in the Miscellaneous Options section to resolve this error.
(3,702 Views)
