NI TestStand
Why does a string looks different for .xml, .html and .pdf Reports?
I guess I should ask you to share your Project to test it in my side as well. Maybe we are adding temperatures in a different way.
Regards)
Message 11 of 17
(1,545 Views)
sorry that I can not share the project. What I do not understand is that the .html file are showing everything correct while the .pdf and .xml file do not. To generate those reports I use the same code, so why the code should be do a different thing?
Maybe the problem is not the report itself but rather the app which shows the report after it has been generated?!
Message 12 of 17
(1,502 Views)
I am using an Adobe Acrobat app for opening pdf files. What app are you using?
Message 13 of 17
(1,498 Views)
Even when I am opening the pdf file with Microsoft Edge it is showing me the correct report.
Message 14 of 17
(1,497 Views)
Well I use both as well but only the html file shows the correct output.
This is the report output of the same project I used. In other words, it is the same sequence file. For me it seems that the conversion somehow fails in TS. But I have no clue which parameter, setting or whatelse has an impact on this.
Message 15 of 17
(1,477 Views)
We are updating from TS2017 to TS2023 and have this issue.
In TS2017 the xml report is showing nice spaces but in TS2023 the spaces are showing up as   which makes the report really hard to read.
Did you get any solution for this issue? Did you get a workaround?
Or how did you solve this issue?
Thank you in advance! 🙂
Message 16 of 17
(1,322 Views)
This might be a problem with rendering the report.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000oxoICAQ&l=de-DE
Message 17 of 17
(1,310 Views)
