NI TestStand
Why is this giving me an error in Test Stand 3.5?
Why is this giving me an error in Test Stand 3.5?  All parameters exist.
RunState.NextStep.Limits.String = Mid( Parameters.WriteData, Find( Parameters.WriteData,   " ", 0, false, false ))
(3,623 Views)
If there in no match with your find() it returns -1, and you cannot have -1 as the start index for the Mid()
Regards
Ray Farmer
Regards
Ray Farmer
(3,614 Views)
Thanks.  So I can pass a variable that could have -1, but not use a functrion that could return -1.
(3,612 Views)
whether you have a variable whose value is -1 or use the return value of a function which is -1, if you use it for the Start Index of the Mid() function an error will be generated.
regards
Ray Farmer
Regards
Ray Farmer
(3,606 Views)
yes, but not during edit time (only run time).  I expected it to fail during run time.
(3,599 Views)
Ah,
Ignore the error at edit time because parts of the expression are undefined at edit time and only available at runtime.
Regards
Ray Farmer
Regards
Ray Farmer
(3,590 Views)
