NI TestStand
Why my custom error message is not visiable in Run-Time Error popup
I am developing a step type where the error information are set via function parameters.
e.g:
int DLLEXPORT DLLSTDCALL Test ( int *iErrorCode, char *sErrorMsg, int *bErrorOccurred )
*bErrorOccurred = TRUE;
strcpy(sErrorMsg,"test");
*iErrorCode = iError;
The iErrorCode appears but the "test" sErrorMsg is replaced by "Error executing substep 'Post'. User-defined error code."  in Run-Time Error popup.
sErrorMsg is passed correctly into TestStand, beacuse I can see the expeted message if  *bErrorOccurred is set to False (step status is not Error).
How can I have my custom error message in Details section of te Run-Time Error popup.
Message 1 of 1
(1,813 Views)
